Overclockaholics Forums » Hardware Section » GPUs » ATI » ATI 5800 Family Photo
Old 09-22-2009
lakeside2189's Avatar
Default ATI 5800 Family Photo
Seems XS put out a 5800 family photo today..Not sure how real it is but it looks close..The 5870x2 4GB has really got me thinking.I hate that!!!!!
Old 09-22-2009
If its real homie, NICE!
Can't wait
Old 09-22-2009
Thing is last time I started with the 4870 and worked my way up...This time i would like to just get 2 x 5870x2 best they have..Can I wait?????
Old 09-22-2009
Gunslinger's Avatar
Overclockaholic
If that is what you want then yes, you'll have to wait. The 5870X2 is not part of this launch, I believe I heard December for that card. But I sure hope I'm wrong.
Old 09-22-2009
I think you are right!! It was that way with the 4870...I will wait this time and get 2 of the best they have....I think
Old 09-22-2009
Default size does matter
It is reported that the
5870 will be 26.65cm long same as the 4870x2
5850 same as the 4870 but
The 5870x2 will be 29.50cm long..I will have to mod the 5.25 drive brackets on the 343b case..29cm max!!!
I look forward to it!!!!
Old 09-22-2009
Yah would be nice if the put the PCIE power ports on the top of the card like some nvidia models, for people that still use cases :p
Old 09-22-2009
Wow, the 5870x2 is almost as long as my...........
Old 09-22-2009
This could be the John Holmes of GPU's!!!!!
Old 09-22-2009
Default Newegg
Newegg has the first showing...
http://www.newegg.com/Product/Produc...82E16814102856
