Overclockaholics Forums » Hardware Section » CPUs » Intel » E759 Bios Update S224
Old 09-22-2009
Default E759 Bios Update S224
Originally Posted by Evga
This BIOS is ONLY for the EVGA X58 SLI Classified Motherboard (part number 141-BL-E759- )
S224 Updates:
  • Improves Bootup Bclock
  • Adds B2B CAS Delay
BIOS updating can be accomplished VIA the below methods:
CD/DVD Installation - Recommended installation method
  • Download the following .iso file: E759_S224.iso
  • Use a CD Burning software to burn the .iso image onto a blank CD (Nero, Alochol 120%, MagicISO etc.)
  • After it has burned, insert CD and restart the machine, go into the BIOS and load defaults, save and exit
  • Now set the CD Drive as the primary boot device, or press escape while the system is booting to select CD as the bootable device.
  • After flash remove the CD, and power off PC Completely.
  • Turn on the PC and load defaults in BIOS
USB FLOPPY Installation - Recommended installation method
  • Download the following executable: E759_S224.exe
  • Insert blank floppy disk into drive and run executable
  • After the floppy has written fully, restart the machine, go into the BIOS and load defaults, save and exit
  • Now set the USB Floppy as the primary boot device, or press escape while the system is booting to select USB Floppy as the bootable device
  • After flash remove the floppy, power off PC Completely
USB Flash Drive Installation - Alternate installation method
  • Download: E759S224.bin
  • Visit this thread and follow the installation instructions. (thanks 30h6).
B2B Mem setting as mentioned by Karmakazi.
Old 09-22-2009
Nice!!!
