Paint
In the last couple pictures in the previous post, you can see some beginnings of some priming of the case.
Now for some shots of the frame painted Satin Black, and some of the prepping and finalizing of the exterior pieces.
Here are some initial shots, and the mess my garage was in, also just moved. Had to organize the garage last night in order to be able to complete everything.
Here are some shots of the exterior plastics, base coated, wet sanded and ready for final painting. Also my Lamptron Fan controller painted:
Hopefully will be back later with some final coat shots, and some other pictures!
UPDATE 8-26-09
Ok few new pictures, got the supports for the motherboard tray in, and the hard drive mount made, so the hard drive will be vented underneath to keep it cool, and slide out the front for easy cable removal and hard drive swapping if necessary. Also got the front of the case modded, and that will get mounted up later.
Will be sanding down the frame, and final painting hopefully finishing up today. Enjoy!
UPDATE 8/29/09
Well I was unhappy with the paint on the chassis, so before final painting, I sand blasted most of the paint back off, and then sanded areas that needed it back down to the metal. Alot of areas where the filler primer was applied were only sanded flat, not down to bare metal, as to try and achieve the best possible finish.
Enjoy the pictures!
I also finished the end caps for the front of the case, to finish off the area where the door would have once been installed. This way the airflow through the front fans is never restricted by the door, but the front of the case appears finished and not missing something.
NOW I'M Happy with the paint!!!
Enjoy the pictures, picking up some more hardware and finishing the painting up tomorrow!!
UPDATE 8/31/09
Ok have a few new paint shots, all the parts are painted. I have reconfigured how I am going to mount my harddrive, so that has been changed. That update will come as the main work on the case gets finished up and I get into the electrical work.
Here are a couple paint shots, more will come later!
