Old 08-20-2009
Ol'Bud Ol'Bud is offline
Ol'Bud is just getting started
Default Enditall 2
little tool to kill processes before bench runs
http://www.docsdownloads.com/enditall-1.htm
Get the zip file
Edit;21aug2009 @0225
I even use the thing for shutting down stuff when not benching.
I had a heck of a time looking for the link for this post,
It used to be at cnet,
But I couldn't find it there.
I hope you all get to try it out.
Old 08-22-2009
spfoam1's Avatar
spfoam1 spfoam1 is offline
Lurker
I can't wait to try this. Thanks.
Old 08-28-2009
Bones's Avatar
Bones Bones is offline
Bones is just getting started
I've used it for sometime now and it does work. Just don't use the "Killall" function or it's reboot city when the NT authority shutdown "Thing" kicks in.
Kills a process XP doesn't like to have shutdown. I don't know if it happens with Vista or Win 7 since I haven't tried it with those yet. Do these manually and it should be OK.
Old 08-28-2009
Hi Bones.
Havin' internet troubles at home I see.
I think it was on one of your screenshots that I saw the shortcut to enditall and I goggled it and that's how I first got it.
Glad to see you back in action.
Also,
Just set the ones that you want "protected" in enditall and it won't shut them down.
Old 08-29-2009
Bones's Avatar
EnditAll is a nice util to have. I normally use it to trim processes for gaming or whatever. Yes, you can set it to protect any process you want.
