08-19-2009
Heatsink/Mem recomendation
Getting an MSI X58 Platinum board (uber cheap) (friday)
Getting a 920 D0 from microcenter (also uber cheap) (soon)
Not going to give up my tuniq on my AMD setup for this, so need a heatsink that performs very well for i7.
Nothing too crazy priced. Thing is getting built piecemeal as it is and I still need to come up with DDR3 for it as well (will take recommendations on that as well )
Thinking about finally getting a TRUE, I would only be running one 85CFM ish Panaflo on it until I can upgrade that. Xigmatek has some real cheap heatsinks, so those are a definite possibility as long as they can handle extreme i7 cooling
Thanks
EDIT: Cheap is more important than top performing...although nice balance would be great...
08-19-2009
alot of people love the cooler master V8, but for heavy clock may not be the best.
Originally Posted by Gunslinger
09-14-2009
Well Kal is letting me borrow his Thor's for a little bit, so still looking at RAM. Found a kit of 6GB reapers for $130, but worried I might not get them for 1-3 months :p (damn Amazon). They are not great OC'ers but 1800 MHz 6 GB kits are not that cheap anymore.
Thinking of actually being a little nutty and grabbing some of those 60 dollar setups at newegg, just to see what I can do with them lol
09-21-2009
Amazon has some super cheap 3GB kits.
$50 3x1GB 1600 MHz Patriot viper extreme ELKs
I should be able to edit SPD tables to generate my own XMP profiles yes?
Anywho they will be here by Friday hopefully. Will not get much a chance to play with them to the next Monday though :(
EDIT: WOW it might be here tomorrow or Wednesday instead. Just checked they have a DC number posted already. It is coming first class mail, I picked the closest shop to me (neighboring state) so 1-2 day delivery time is expected (Not Amazon's prediction, but mine )
09-25-2009
Well well, what is this we have here? A rather weighty box from Hawaii, looks like I have some work to try and get done today, in a few short hours :( Must protect Asgard!!!
Still looking for recommendations on a heatsink to buy so I am not borrowing this beasty for too long Near to the top for i7 performance as possible, but price must be a consideration.
thanks
09-25-2009
The V8 is ok but for the money invested I would get a True.
09-25-2009
You're not borrowing knucklehead, you're keeping it, courteousy of your friendly neighborhood team captain.
Its a good heatsink brudder, just a bitch to constantly switch out for ln2/dice pots. Be sure to visit that thread on proper tim placement and you'll be pleasantly surprised by air performance.
09-27-2009
Thanks again Kal
WEll spent hours getting this thing put together perfectly. Pulled the little rubber fan clips off my Xigmatek Battle Axe cooler to mount the panaflo to the Hammer. Read the thread on tim application, wire managed the bench station, everything looks great.
Used DVI cable (which may or may not be bad) power up... nothing.
Pull it and pop on an adapter and VGA cable. Still no video. ARGH
Left system running, after 15-20 seconds or so it shuts off, and then powers back up and repeats.
Can't test individual components, but my guess would be motherboard :( Going to see if there is anything unusual on this boar that I am missing, but I doubt it.
09-27-2009
nm, I am a tard. Hooked up a speaker, got a 3 beep code, started looking at it, and thought about PCIE slot... manual says first black slot. (mine are blue) So looked at DIMM slot population
It goes CPU Dimm 2, dimm1, dimm 4, dimm 3, dimm6, dimm 5 and you have to populate ODD slots duh
so had to pull the fan off the hammer and move the sticks
Got to post screen and turned it back off.
09-27-2009
Hehe, Noob4Life
